RE: Onboard Alternator
That is similar to how a turboprop/turboshaft engine works. The difference is that they are designed to convert the accelerated exhaust gases back into mechanical power.
In a turbojet (model engine) the power is gained directly from the high velocity exhaust. Anything that is put in this gas flow will significantly reduce the power output of the engine.
