RCU Forums - View Single Post - BME CAP Maniac
Old 11-26-2004 | 04:31 PM
  #49
drumbum's Avatar
drumbum
Default RE: BME CAP Maniac
Thanks i found them.... Also when i looked up in the hole on my wing that is parallel to the hole the srvo lead comes out I noticed the 3dr rib was cracked down the center. so i decided to look down the second it was shattered....
Put some cap strips like on ribs 1/16 X 3/16 and let the extra overhang inward so it is not seen and then trim them accordingly.. I had to do that on my U-Can Do belly pan.. then i painted the wood where you see it white. that would be the same in this case. If you have to keep stacking them and then sand untill they mate with the wing properly.
