RCU Forums - View Single Post - BME CAP Maniac
Old 11-27-2004 | 07:55 AM
  #50
TManiaci's Avatar
TManiaci
Default RE: BME CAP Maniac
The build continues...
Here is the filler job on the belly pan before re-covering. Then the finished installation. The fillers were 1/8 x 1/4 laying flat, then trimmed and sanded until we got a good fit. We used white Ultracoat to cover, and a white silicone fillet to finish. The pan was too wide at the front too, by almost 1/8", and the edge radius didn't match the fuse. We made it all right. Looks sweet now. We used thin CA to install, as the glass job on the wing joint made it so the belly pan does not need to be a structural member. We wicked in thin CA in the center 80%, and finished the ends after wing removal to avoid gluing the wing into the fuse.
ID:	196936   Click image for larger version
