RCU Forums - View Single Post - Emcotec Regulator & Switch
Old 11-27-2004 | 10:55 PM
avionics12's Avatar
avionics12
My Feedback: (12)
Default RE: Emcotec Regulator & Switch
Copied from the Emcotec manual:
Because the distribution voltage is switched on electronically (the
switch does not activate any current, but rather only the switch-on
signal), no losses, contact errors or transition resistance occur. This
internal electronic switch is fail-safe. Thus, a switched-on “DPSI RV /
RV Mini“ remains switched on even if, for example, the On/Off switch
is separated or interrupted.
I believe that if this works as advertised then it would qualify as a "fail safe" switching method.
