RCU Forums - View Single Post - Calculating compression ratio
Old 11-28-2004 | 05:31 AM
Motorboy's Avatar
Motorboy
Default RE: Calculating compression ratio
Hi, you can calculate totalvolum of stroke (not all ports are "just"closed, allways from BDC to TDC) and bore and measure volume of combustion volume in cylinderhead (use syringe with sewingmachine oil to measure volume with piston at TDC and fill oil until plughole).
The formula are:
Totalvolume of cylinder + combustion volume : combustion volume = Compresion ratio
Jens Eirik
