RE: Calculating compression ratio
Engines have a mechanical compression ratio measured using the total bore and stroke and an effective or "corrected" compression calculated from when both valves are closed on a fourstroke and from where the exhaust port is closed on a twostroke. You would amazed at how far up on the compression stroke the piston is on a Saito before the intake valve closes.
