RE: DP Ultimate Pull-Pull?
I did two DP Ultimate 40's. The first one set up per instructions. I ended up with a slight roll whenever I pulled up a lot of elevator. In the second plane I mounted the servo under the canopy floor with the servo arm running vertical and on the centerline. That way it was more likely that both elevator halves would move the same distance. It worked. I didn't have the rolling problem with the second setup. Anyway, good flying.
