RE: Funtana 90 and CA hinges
The change was a simple running hange t the wing. We arent planning any exchange unless your wings that you received in your kit were broken. I believe in some cases the aileron servo pull out when the rub the servo rails attach to are either cracked in shipping or cracked when the servo was installed. Either way, they seemed to crack more easily than I would like to see so we made the change. Check your wings over to be sure they have no cracked ribs in that area, if they do, call in to our Priduct Support people.
I was at our factory in China yes, but the shipments of the F90 withthe revision had already shiped and was in stock here. I primarily go there to work on new projects and to make sure general quality is always going up.
