RCU Forums - View Single Post - First parkflyer help
Old 11-30-2004 | 09:13 AM
Crashem
Default RE: First parkflyer help
Losibasher,
I'd listen to a65L the slow stick is a good first plane if stick type planes aren't appealing to you look at the Tigermoth. Unfortunatly aerobatic plane and first time flier isn't really a good combination unless you like crashing more then flying
The Good thing about the GWS planes is that the radio gear be moved from one plane to another as you gain skill.
You can get the tigermoth for about 55.00 the flight pak is about 75-80. and extra battery will cost 20-30 a cheap 4 ch Tx is about 100
and the one item I would not skimp on is the charger get one that can charge Nicad, Nimh an Lion batteries about 80-125
Expect to pay about 300-350 for your first setup but remember that the charger and radio can be used in other models so when you are ready for the Zero you will need a different battery, ESC and maybe one servo.
