RCU Forums - View Single Post - First parkflyer help
Old 11-30-2004 | 12:48 PM
e28m5
Default RE: First parkflyer help
You will likely have a bad experience w/ any of the GWS warbirds. They fly fairly quickly for their size yet are somewhat underpowered so they fly on the wing. In other words, you can't rely on throttle to get you out of trouble. They drop out of the sky real fast if you are a little shaky on the sticks. I have a smashed up Corsair to prove it. The Me109 is probably the easiest to fly, the Mustang the toughest. It's tough to beat the Slow stick or TM for cheap, good-flying starter planes. If you want ailerons, get an estarter, also cheap and can be flown first just using the rudder. Then you can cut the ailerons out later. The estarter is more of a handful in general than the SS or TM, it's heavier and faster. Depends on your experience level.
