RCU Forums - View Single Post - CG Ultimate arf help!!
Old 08-22-2002 | 12:34 AM
SearchMan
Default CG Ultimate arf help!!
Setting Control Surface Travels:
Aileron: Gentle= 10 degrees, Aerobatic = 12 degrees
Elevator: Gentle= 12 degrees, Aerobatic = 14 degrees
Rudder: Gentle= 15 degrees, Aerobatic = 23 degrees
The manual suggest that you start by flying this model with the High rates set at the Gentle settings and low rate set at 75% of the Gentle settings.
Hope this helps,
SearchMan
