RE: GP Ryan STA
I am building the STA-M with OS120 w/pump. I have a few questions for those of you that have built one....
1 - What servos do you recommend using on the STA-M? I have never used Hitec servos before, but was planning on using the following Hitec servos:
Rudder and elevator = Hitec HS-625MG
Aileron = Hitec HS-635HB
Throttle = Hitec HS-325HB
Does anyone have any experience with these particular servos......the only requirement called out in the STA instructions is for servos with a minimum of 50oz/in of torque for the rudder and elevator.
2 - What battery set-up are you guys running?
3 - I want to install some wire stays (more for appearance than functionality) per the prototype. Has anyone attempted to do this and what products are available on the market that would make this work "easier"?
Dick T: Do you make graphics for the STA-M and do you have a website?
Thanks!
Ed
