RCU Forums - View Single Post - HELP- big problem
Old 12-03-2004 | 01:32 PM
Pops Racer
Default RE: HELP- big problem
Alot of people will just splice in a piece to repair the cut/broken antenna wire. This can lead to range problems if the wire is different in gauge or total length. Also a splice that is not insulated could be grounding out on some CF or metal part(s) causing your problem.
Best to completely replace the antenna wire with a NEW piece of the correct spec, by soldering to the board.
Consider that a crash severe enough for the blades to strike the antenna wire close to the RX, may have damaged the RX or it's crystal.
