RE: cutting a taper
Vicman I am making a basic prop adaptor for a Poulan 42 cc I don't have the exact dimension right now but here's about what I'm doing
engine shaft .449 tepres to .33 or so
I would like the shaft to slide in the adaptor a bit say 3/4" then cut the taper then allow for the shaft nut after that I'll just make up a four bolt prop setup up front I can take a pic later
Den
