The guide tubes are designed to provide support. I would not suggest that you remove any of the guide tube material between the bulkheads as this will most certainly give the pushrod room to flex. If the pushrod is binding, you need to find the problem and fix it.
Give them young Marines a hearty OOHRAH for me!
