RE: Ryan STA Kit by SIG - I need advice!
Chris,
I have not conributed to this thread an a long time because I have not been working on my Ryan. But I did just purchase fiberglass wheel pants and a cowl for the kit. The ones from the kit seemed to be a rather daunting task to put together so I took the easy way and bought them and they do look pretty good. I will probably begin to work on it again but I need to go back and do some more mods. I will be changing the aileron servos from one to two which will require making servo holders in the wings and removing the horns that I have already installed. I will also continue to modify the landing gear as described by Nichrome earlier in this thread. I have beefed the blocks up and glassed the center section but I have not put the extra rod on the supplier gear. I can't say when I will be getting to it again but I may be able to snap a few pics of the project as it sits today? I got a lot of good advice from Nichrome as he has built more than one of these kits. Bishwheeler also seconded the advice from Nichrome so it would be wise to refer to these guys if you have any questions. I would also be more than willing to help in any way I can. Good luck.
Scott
