RCU Forums - View Single Post - Ryan STA Kit by SIG - I need advice!
Old 12-04-2004 | 11:47 AM
  #53
SNIGGEMANN
My Feedback: (10)
Default RE: Ryan STA Kit by SIG - I need advice!
Starskipz,
I also have flaps on mine but I don't remember the throw angle. I concur about using two aileron servos and also beefing up the landing gear. One other thing to repeat here is to not use the plastic hinge material supplied. Use Robart pin hinges and add extra balsa in which to insert them for all control surfaces. Unfortunately I had installed the supplied hinges and sheeted the center section before I learned about the necessary mods. I then had to rip out the hinges and also rip off the sheeting for the center section to beef up the gear block supports as described by Nichrome earlier in this thread. If any one has the ability to take and post some pics let's do so. It would be interesting to see how everyone is doing on this kit. Also, Sig no longer makes this kit so if you have one consider yourself lucky although I have seen a couple for sale in the last year they have been very few and far between. Good luck.
Scott
