RE: contender tail crooked
OK Miami, you are still ok. when you glue the stab and fin on just be sure they are centered. Should not make too much difference in how thw plane flies. There is very little offset there. If it concerns you you could cut the fuse sides at the tail and re glue them. Use a small piece of balsa in the nothc to reinforce it. Too be sure the glue joint is good. That should be a simple fix. Don't sweat it too much. Just take your time and be careful and all will be fine.
Mark Shuman
