RCU Forums - View Single Post - Typhoon 2000 (TEMPEST) modifications thread
Old 12-05-2004 | 07:15 AM
  #105
sigk's Avatar
sigk
Default RE: Typhoon 2000 (TEMPEST) modifications thread
Wladimir, so you are building your own design, that's great, keep us informed.
About the white glue, I have tried it and wouldn't use that on a pattern plane. It will only give you a soft finish. I know of nothing that gives better result than epoxy. I have tried polyurethane glue and I think that comes closest to epoxy. But the epoxy gives you so much better finish. If you don't like to use epoxy, there was a excellent article in Radio Control Model World august 2003 issue, about using polyurethane lacquer floor seal as an alternative to epoxy. It has very little odor, gives a very hard finish, is non toxic and impervious to glow fuel. Sounds almost too good !
Sig.
