RE: contender tail crooked
It's probably a good thing that you cut and reglued the tail. Remember the top and bottom fins on the Contender should be in alignment as the rudder hinges to both of those above and below the fuselage. If you had left it alone, you could have set the stabilizer correctly, but the fins and rudder arrangement would have been out of whack. Good job.
Robert92679
