RCU Forums - View Single Post - Removing Tx frequency module for AFP
Old 12-05-2004 | 02:07 PM
Josey Wales's Avatar
Josey Wales
My Feedback: (61)
Default RE: Removing Tx frequency module for AFP
If your tx has a square port on the back then it will work..The way it was explained to me is that it uses very little power because you are not transmitting a signal..When you are transmitting the signal then it is using power as if you were actually flying..
