Go Back  RCU Forums > RC Airplanes > RC Flight Simulator Software
 Removing Tx frequency module for AFP >
RC Flight Simulator Software Discuss rc flight simulator software here. Aerofly Pro, RealFlight G3, XTR, Reflex, etc.
Old 12-05-2004 | 10:36 AM
JoeAirPort's Avatar
My Feedback: (41)
Default Removing Tx frequency module for AFP
Can the frequency module be removed so that the battery charge lasts longer on my 4YF or my 6EXA? Also I don't want the transmitter sending out a signal in my neighborhood. I can do this on my AM tx but not sure about the 4YF.
Old 12-05-2004 | 11:24 AM
Default RE: Removing Tx frequency module for AFP
You should be able to pull the crystal module out from the top of the radio. Makes the batteries last for a long time.
Old 12-05-2004 | 11:28 AM
Luftman's Avatar
I remove my crystal anytime im using AFP, I just pull it out when using the sim and pop it back in when done so i dont lose it. This adds serious time to my charge and supposedly dosent fry the Tx internals by sending signals w/ the ant. down.
Your crystal is on the lower left of the front, should slide right out.
Josey Wales's Avatar
My Feedback: (61)
I have a plug I got from OMP for my 9c that bypasses the module and just turns th TX on..Maybe there is one for your radio..I would check on their website.
Old 12-05-2004 | 01:53 PM
JoeAirPort's Avatar
My Feedback: (41)
I think this is for all Futaba radios that have the square mini connector. I just ordered one. I'm not sure if it will bypass the frequency module and save battery power though. Who said it does that? I can just pull my crystal if it doesn't bypass it.
ORIGINAL: Redrum
Old 12-05-2004 | 02:07 PM
My Feedback: (61)
If your tx has a square port on the back then it will work..The way it was explained to me is that it uses very little power because you are not transmitting a signal..When you are transmitting the signal then it is using power as if you were actually flying..
Old 12-05-2004 | 05:26 PM
Bud Faulkner's Avatar
What about real flight G3? What do I do to my futaba trans?
