RCU Forums - View Single Post - Rustler ?'s
Thread: Rustler ?'s
Old 12-05-2004 | 02:36 PM
**MilkMachine**
Default RE: Rustler ?'s
hold up!!! no matter how you shut off your engine you are always going to make it lean except if you plog up the carberator. but if your run your tank empty you will run lean, and if you pinch the fuel line then you will run lean! plus you dont want to leave gas in your car.
SO BURN IT OUT!!!
Andrew
