yah!
if it takes you like 7 pulls then you need to tune it
4-5 turns tune it alittler
1-4 turns its ok
if its very hard to pull then you need to tune it
you should cary the pullstart becasue
1. less weiht
2. dont need to buy a battery
3. i dont think it breaks that easily cause myne only broke by pulling it all the way and ripeed the string off
tips
1. dont get pisted off if it wont turn on just tune it
2. dont pull the full length cause you can rip the string off
3. for faster starting exelerate alittle while you pull
4. pull straight out if you pull down or up it causes frictiona nd wheres out the string
4+5. try to make it go like the pullstart box \ then pull the string \ if its / pull the string / . \ + \=
thats all i can think off
