RCU Forums - View Single Post - panel lines how to
Old 12-06-2004 | 11:40 AM
BobH
Default RE: panel lines how to
In addition to the advice already given, be advised that your model may not exactly match the drawings showing the panel lines. This happens because typically your model is not 100% scale in all respects. When this happens you need to make "adjustment" on your plane to get the layout to appear correct. A little artistic license works here if you understand my meaning. Aside from that, panel lines are one of the easier things you can do to spruce up your plane.
