RCU Forums - View Single Post - Shock flyer brushless mount
Old 12-06-2004 | 05:09 PM
TooLy's Avatar
TooLy
Default RE: Shock flyer brushless mount
ORIGINAL: moses
I also order the AXI radial mount kit – but I only use the prop adapter (kind of expensive just for a prop adapter). This set up has been holding up really well.
You didn't reverse the shaft If you use the prop adapter from the axi radial set.
MJP Carbon show in the site the motor with the collet 3.2 mm adapter, for this you have to reverse the shaft .
http://www.rcuniverse.com/forum/upfi...19/Ig12288.jpg
I saw these tiny antennas, nice, I will get one next order.
About the props, I got two new apc and they didn't fit the 5 mm adapter shaft, even with the prop inserts they came, so I took the small one and manually drilled it a bit and it fit perfectly.
