Shock flyer brushless mount
HI,
I'm about to order the new Ikarus Yak 54, my 2208/34 axi looking for home and I would like to know if I should also buy the Shock Flyer Motor Mount for brushless ?
I know I can get the radial mount set and use a 45mm-diameter lite-ply disc but since I already order from ikarus I can get their mount too.
Thanks.
Thanks.
Iβm not sure if I understand your question. The motor mount in the picture looks like the mount from the Ikarus Brushless Power Set (which does not use an AXI motor). Iβm guessing that this will not work with the AXI β¦ canβt say for sure.
I can tell you what I use; it seems to work well. I ordered a carbon fiber mount from www.mjpcarbon.com (click the buttons for Products β¦ then R/C Planes).
I used the AXIRRM-0 style mount. This mount allows you to radial mount the AXI 2208 directly (i.e., without using the X shaped back plate). The only down side is that I had to attached the motor to the mount and then glue the mount to the plane (the motor mounting screws are blocked once the mount is installed).
I also order the AXI radial mount kit β but I only use the prop adapter (kind of expensive just for a prop adapter). This set up has been holding up really well.
Check out this thread entitled βShock Flyer Carbon Fiber Mountsβ http://www.rcuniverse.com/forum/m_21...tm.htm#2192609
Look at post #12 β I followed imsofamanβs example and mounted my AXI exactly like this (including the carbon fiber tape strips to strengthen the edges as shown) β like I said, works just fine.
I see you are in Israel. Ordering from multiple places probably drives your total cost way up β sorry.
Good luck,
Moses
Good luck,
Moses
So the shaft of your axi coming out from the plane side ?
I know I can reverse the axi like in the photo I added, I saw in the link you gave me that they do it also.
If I reverse the shaft and use 1/8 inch collar I can use my 3.2 prop adapter that I already have.
Good to know about the fiber mounts, looking good.
I thought I can trim the ikarus mount a little bit so it will fit the axi.
Thanks.
Thanks.
That is interesting that the Ikarus mount will work for the Axi. It looks like the Ikarus mount attaches directly to the nose of the plane. I wonder whether people have good luck with these (does not look like these style mounts have much glue area). Perhaps somebody can comment on how well the Ikarus mounts hold up with an AXI. With a 3 cell Lipo, these little motors produce a lot of thrust for such a light plane.
As for your other comment, yes my motor is reversed β the small shaft points toward the tail, the prop adapter is attached to the opposite end of the motor. I forgot to install the collar - but the motor has not pulled apart yet
You may also find the following site interesting:
http://www.ecubedrc.com
They sell Azarr antennas β tiny base loaded antennas. I use the M-72-6. It weighs 0.5gm and is attached directly to the fuse. No wires hanging down, no problems with range or glitches.
They also sell APC Metric Prop Inserts (for S400 and Slow Fly Series Props). These are great if you are going to use an APC slow flyer prop. Here in the US these props come with non-metric prop inserts; I believe the AXI radial mount prop adapter is 5mm. These metric inserts just pop in and the prop fits perfectly. You may be able to order these from some other hobby shop.
Good luck,
Moses
Good luck,
Moses
ORIGINAL: moses
MJP Carbon show in the site the motor with the collet 3.2 mm adapter, for this you have to reverse the shaft .
http://www.rcuniverse.com/forum/upfi...19/Ig12288.jpg
I saw these tiny antennas, nice, I will get one next order.
About the props, I got two new apc and they didn't fit the 5 mm adapter shaft, even with the prop inserts they came, so I took the small one and manually drilled it a bit and it fit perfectly.
Thanks very much for pointing that out, great picture. You are correct, I did not reverse the shaft β¦ that is pretty funny
I realized that I did not use the collar β¦ after I mounted the motor
I did not want to tear the motor back out β since the screws are hard to reach. I actually did not realize the shaft was reversible.
I trimmed a tiny bit of the foam to clear the shaft. I then used four pieces of balsa tri-stock to stiffen the entire nose section (top and bottom). So basically I formed a tiny little pocket in the front of fuse to clear the shaft.
So I guess the prop adapter has a hollow bore to receive the shaft. I also guess the shaft provides some strength to the prop adapter since the shaft is hardened.
My setup is working just fine. I fly the thing a few times a week β itβs a great setup. But, Iβll make a point of reversing the shaft on the next one.
Strange that the metric prop inserts did not work for you; mine snapped right in and fit perfectly.
Moses
I did not want to tear the motor back out β since the screws are hard to reach. I actually did not realize the shaft was reversible. I trimmed a tiny bit of the foam to clear the shaft. I then used four pieces of balsa tri-stock to stiffen the entire nose section (top and bottom). So basically I formed a tiny little pocket in the front of fuse to clear the shaft.
Moses
Here you can see how to reverse the shaft (posts 18-19)
http://www.rcuniverse.com/forum/m_23...tm.htm#2381539
imsofaman had the reversed motor with a collet 3.2 mm adaptor, he reversed it and used that adapter to save weight, instead leaving the motor originally and mount the prop adaptor from the radial set.
But now he have the prop adaptor from the axi radial set like you, this is what he told me:
"make sure that your prop adaptor is fluch against the outrunner can. I have found that if there is a space in between the adaptor and the can, exposing the axle shaft....the axle flexes during flight and you get a vibration and loose major RPMs. That is why I change it back to the normal style with the mounting kit. If I were you....I would purchase the mounting kit.....it makes for a more solid performance".
Another interesting thread:
http://www.rcuniverse.com/forum/m_21...tm.htm#2193023
Now my problem is that MJP Carbon told me they can't send to Israel, I might order the Ikarus mount or reverse the motor with plywood mount see how it works before getting the radial set.
Thanks for pointing out those threads. In my setup, the aluminum prop adapter is very smooth, no vibrations at all.
After doing a bit of reading, it appears that reversing the shaft is not necessary. Look at imsofaman's post number 8 in this thread:
"Hey guys.....I think you are correct about the shaft bending. I actually changed my set around back to the stock set up with the axle mounting kit for that motor. One thing that I discovered was using the mounting kit for the motor...the aluminum shaft that bolts to the front of the motor is very solid. before...doing it my way with a modified shaft....I had vibration on the prop. with the aluminum axle....no vibration...solid and smooth. "
So I must have guessed wrong, apparently the aluminum prop adapter does not have a bore to accept the reversed shaft. It also appears that reversing the shaft requires disassembly of the motor - and perhaps some difficulty removing tiny allen screws.
If I were you, I would do what ever is simplest. I like the radial mount since the aluminum prop adapter works great (even if you have to hand ream the prop insert). You probably can't go wrong with either a modified Ikarus mount or a plywood mount. Too bad that MJP can't ship to Israel - we are spoiled here in the US - low cost mail order shipping is almost always available.
Good luck,
Moses
Good luck,
Moses
