RE: Rudder servo pull-pull installations
Looks to me like his control horn is right on the hinge lines . Actually most people have a
tendency to run their wires too tight anyway. They should not pull hard on the servo as
this will cause the output shaft bearings to wear prematurely. If you use quality pull-pull
cable that doesn't stretch it doesn't have to be as tight as a guitar string. Too tight makes
digital servos buzz all the time also.
tommy
