RCU Forums - View Single Post - canard flap location..??
Old 12-09-2004 | 09:09 AM
Johng
Default RE: canard flap location..??
THis is a cool discussion that has spurred a few ideas that I'll just throw out there in a stream of conciousness:
IF - you are really just looking for a way to get in and out of a tight field there are other solutions. Use the flattest pitch prop that still gives you the up-n-away performance that you want. I've tamed more than one floater by going with a bigger, flatter prop - which generates more drag at idle on approach. It'll improve vertical performance too, which will help avoid the trees on climbout.
Also, concerning landing, you might just want to deploy a drag device to help make the approach steeper. Something like a big 'ol bellyboard speedbrake like on the F-111 or F-100 would allow ou to dive in without picking up speed, while not destroying lift like a spoiler would. Space shuttle approach, baby!
Nate is correct about needing the canard to stall first and still provide lift when the wing is at zero lift. There are other ways to achieve this besides airfoil selection or modification(flaps). You can play with the canard loading (cg location) to get the canard loaded higher, so it must function at a higher angle of attack, closer to stall. This could impact maneverability in aerobatic flight though. Also, a higher aspect ratio wing will stall at a lower angle of attack. And, remember that reynolds number is a big consideration at model sizes - as Mike j can tell you first hand from his long-ez experience. The canard chord can be so small, that it won't provide enough lift to get off the ground. While this can be a headache, you could also tailor it to be a feature that provides stability at approach speed while still being manueverable in up-n-away flight. Of course, this figures into the aspect ratio equation as well. All of these things involve a real balancing act that would take some serious tweaking and forethought.
I might suggest that you consider NACA leading edge droop on the main wing, or even LE flaps to allow it to function at a higher angle of attack. Then use flaps or even slotted flaps on the canard to drive the angle of attack higher. The LE flaps don't add much drag themselves, but they allow the whole plane to get nose high which will be draggy in itself.
