RE: Twist gets downed by kamikaze 1/2 A air to air missile
The missile chipped a prop, the wing separated from the fus and the leading edge that took out the Twist wing had a chunk out of it but was otherwise intact.
Big lesson learned on this one. Make sure you have clear airspace especially if you are going to go vertical straigt up above the runway. Most people expect a normal roll out on take off.
