RE: DA50- Anybody Having Trouble?
I have 2 DA-150's both running on 100:1 since they were broke in. They have been back for updates to DA and Dave at DA stands behind mixing 100:1 with oils that are made to run that lean. Amzoil being one of them. I beleave people are taking oil designed to run 50:1 and running at 100:1 because they were told it would work. I have alot of gallons through both of mine with no problems. It seems to me the problem with the DA-50 has been discovered that the rod was not good enough the first time around. If DA is fixing this problem under warranty they understand there is a problem with the design and i'm sure they will do everything to fix it.
