RCU Forums - View Single Post - Pls help! What is the proper procedure to break in a ringed engine?
Old 08-25-2002 | 02:40 AM
CAP232CM's Avatar
CAP232CM
My Feedback: (8)
Default Pls help! What is the proper procedure to break in a ringed engine?
No I have not broke in mine yet but I know a dealer for Irvines that has said when they are broke in there is a noticable difference in the exhaust tone and you will be able to hear a big difference. The power will come way up after this as well.
As far as how many gallons, I don't think that is a good way to tell as all engines are different, but I'm sure 2 is close. My dealer said after 5 or 6 gallons you can really tell a difference.
If you just use some common sense with the irvine you'll be fine. Always make sure that you see a smoke trail while flying. If you don't it's too lean.
