RCU Forums - View Single Post - XCELL 60ST - Clutch problems
Old 08-25-2002 | 03:04 PM
ppljr's Avatar
ppljr
My Feedback: (94)
Default XCELL 60ST - Clutch problems
I got a used Xcell .60 ST and had to change the clutch lining. My problem is (other than the lining costing $25) is that it is too big. I can't slide the clutch shoe into the bell with the lining in. I haven't glued the lining in, that should make the fit even tighter. What options do I have? I suppose I could grind some of the liner away to make the shoe fit, but how do I grind it down evenly. Furthermore, how much of the lining is there until you hit the metal part? Any other suggestions?
PPLJR
