RCU Forums - View Single Post - XCELL 60ST - Clutch problems
Old 12-20-2002 | 10:50 PM
Dave Wilshere
Default XCELL 60ST - Clutch problems
Guy's
It's a common surprise to find it doesn't fit.
The big thing about MA clutches is that if you don't hot start them they will out last anything on the market (maybe bar a heim clutch)
The fit of the shoes-to-liner is very critical. All the problems with the Raptor clutch come from the larger than ideal gap between shoe and liner. Plus the lining material is about as tough as toffee.
The MA liner is expensive, but it's quality and I have managed seven years flying on one liner/clutch.
The liner is overly thick to allow you to machine it to fit. Glue it in first, then machine it-This stops excessive glue build up leaving a high spot.
Ideally you should take your clutch unit to a machine shop and get the liner trued and sized to suit your clutch. If the shoes have been overly stretched then it should be changed now.
The MA clutch is king
Dave Wilshere
UK
