RCU Forums - View Single Post - U-CAN-DO 3D .60 HELP!
Old 12-13-2004 | 06:48 PM
gjeffers's Avatar
gjeffers
Default RE: U-CAN-DO 3D .60 HELP!
ORIGINAL: srxripper
SAITO 100 ISN'T ENOUGH! PLUS THE SAITO HAS FLAT SPOT THREW THE THROTTLE TRANSITION WITHOUT A PUMP! I HAD A CLINE ON MINE TO FIX THE PROBLEM! ANYWAYS I WAS RUNNING A 16*4W APC ON THE FA100 W/15% WILDCAT, IT TOOK ALIITLE TIME TO SPOOL UP!, BUT IF YOU A YS110 YOU CAN GO UP TO A 17INCH PROP WHICH I HEARD MAKES THE PLANE HANDLE MUCH BETTER! I GUESS IT HAS SOMTHING TO DO WITH THE PROPWASH, PLUS THE YS HAS A BUILT IN PUMP SO YOU CAN LOCATE THE FUEL TANK NEAR THE CG
HOPE THIS HELPS!
saito 100 is enough engine for a lot of people it just depends on your skill level and im almost to that point where i want more also but i think the saito100 was a great engine and i had no problems w transition on mine but i went to a cline to move the tank over cg so i think a lot will agree the saito 100 is enough for a ucd 60 if your just starting 3d.oh and if you need more power use coolpower 30%.
