RE: Help Setting up Saddle Tanks and Hopper
Ernie,
Here's the BVM instructions. As bcovish said, keep the fuel and pressure lines to the saddle tanks the same length. After I plumb mine I usually fill and drain them several times using my electric fuel pump to make sure the saddles drain at the same rate. If they don't, shorten the fuel line to the tank that takes longest to drain a little bit at a time untill they drain at the same rate.
Joe
