RCU Forums - View Single Post - Cutting Slots for Ribs, quick tip
Old 12-14-2004 | 10:56 PM
tperry2054
My Feedback: (15)
Default Cutting Slots for Ribs, quick tip
Hey all,
Laugh if you must but here is an easy way to cut some small dadoes for snugly fitting wing ribs:
Tool is made for desired width by selecting right size of sabre saw blade and using two Bulldog clips and two popcicle sticks for controling depth of cut. In this example it cuts a snug 1/16" width and is adjusted for 1/8" depth.
To use I make a small tic mark and use a small right angle square to align the cut. Results are shown in second two pictures.
I prefer to use my saw table with the mitre guage and a small blade, But the cold season is here and my shop is detached from the house and unheated.
Notice my cold weather building board perched on the chair arms in my den/computer room.
The ribs fit snug enough in leading edge and trailing edge to dry fit, check alignment and dribble in som CA.
Notice the smaller Bulldog clip holding the leading edge in position.
Tight lines,
Tom Perry
ID:	203067   Click image for larger version
ID:	203068   Click image for larger version
ID:	203069   Click image for larger version
