DP Extra FIRST Flights
Well it's good to hear a succesful story of this plane after reading the problems some other modelers have had. A buddy of mine has one on back order due in about 6 weeks. We have everything figured out except for the power issue. We're thinking of a Saito 180 but with the tail heavy situation are considering a heavier and more powerful gasser. How about your balance issues and your servo locations. Did you mount them in the rear or use DP's modification to the pull pull elevator and rudder installation? Also I heard something about them moving the wing back to solve some CG concerns and if this is the case is this the version you recieved? Thanks for any help you might bring to this issue!
