Originally posted by Coulter_Dean
It seems the adhesive is not near as strong as Monokote's.
True, but the adheasive also allows for removal which MK doesn't
I had to go over an area four times to get it to stay and shrink down to no sags, and each time I did, it would pull away from the seams, leaving an unstraight color line.
You had your iron too hot
Ultracote Will NOT go around compound curves and edges anywhere near as well as Monokote.
Two words: Bull S#@T
When I get lazy and want a good look, what I do sometimes is cover the wing in Monokote, and the fuse in Ultracote.
So you're admitting that Ultracoat is WAY easier to use.
I rest my case.
