AFPD - are there 2 versions??
I know that AFPD comes with a cable that will allow you to use your own transmitter. I also know that in January a version of AFPD is going to be released that comes with controller. So the question is, if you get the version with the controller, would you be able to get a cable and then use your transmitter with it? OR if you get the controller version are you stuck forever using the controller only? Haven't been able to find the answer to this so was hoping someone might know.
