RCU Forums - View Single Post - Phoenix Giles & Sukhoi which engine
Old 12-17-2004 | 08:56 PM
FlooredCOBRA
Default RE: Phoenix Giles & Sukhoi which engine
I think a .61 will do fine.
I started out with a .46 FX on first few flights. I did well but I felt the power was low. I took it out and am now flying it with a MVVS .77 and mini pipe set up. I like big props and this thing turns them no problem. I'm using a 14x6 and it has tons of pulling power and will accelerate going vertical. I also ran a 15x4 before and it also ran good. Just a bit close on ground clearance.
It is a little bit heavier but no different nasty habits. I used the same engine mounts and havent had any problems yet. It fits nicely in the cowl since the cowl is a pretty good size.
ID:	204123   Click image for larger version
