RE: Cannot switch Resolution beyond 640x480
PROBLEM SOLVED!
I had a hunch over a nights sleep and woke up, tried something and it worked. Turns out AFPD Does not like any kind of GUI running on the desktop. I am using WindowBlinds (latest version) and for some reason there is a conflict with it. I unloaded it and as soon as I did AFPD worked normally. I am not sure why this is, all other games, sims, etc have no issue with this, but there must be some function call in AFPD that interferes with Windowblinds or vice versa....
I can now run at full 1600x1200 resolution with no problems... LOOKS AWESOME!! I am very pleased with the AFPD. I would like to not have to unload windowblinds every time I use it, but for now... I'll deal with it!!
I also cured the erratic behavior of my 10X... it appears that AFPD needs to see PPM set up as the modulation type, not PCM... as soon as I changed that the 10x came to life.
2 plane mode is very cool!! I can totally use my G2 box, and someone else can fly the 10x... amazing
So far AFPD is everything I thought it would be!!
DP
