That was an awesome explanation. I could follow you perfectly on every maneuver description. I appreciate that response. I'll be awaiting your video if you'll let me know when it's available.
Let me know if I have the idea correct here. In a competition... Say it was my turn to take to the sky. The judges would tell me when and where to begin from. Then, I'd have 2 minutes to take to the air. Correct? I would then get airborne heading upwind. Would my first maneuver have to be on the first downwind approach into the !QUOT!box!QUOT!? Also, each maneuver if placed correctly in the box, should allow me to continue onto the next maneuver, correct? Say my first maneuver is the roll(downwind) directly after turning around after take off. Then after completing my roll in the first downwind pass, I would directly go into the sharks tooth at the downwind side of the box? Then after the sharks tooth, heading upwind, I would then move into the stall turn.... And so on, and so on. Am I correct on how it works? Then after my last maneuver I have 2 minutes to land?
I probably just confused the hell out of you. I just want to get the whole process understood, so I can practice it from start to finish.
So much to learn!
