RE: 46 CC ITALIAN ENGINE.
Hi:
Today I reassemble the hole engine together again after a deep cleaning inside and outside.
The remaining ring in the piston was placed on top, and the engine has the same compresion as before. may be at higher rpm that "hand turning" should be a difference, but I think i will try just like it is.
I was about to use it with the flywheel using a hub from one of my ryobi or homelite, but the threads are not the same, so there is no need to do a hub for the flywheel and later another for the ignition I have, so i´m going all the way at once now and will place the ignition directly to test it with the Top flite power point 20x10.-
Hope one of you have some info about the engine.
Tato Lazo
