RCU Forums - View Single Post - Field Box
Thread: Field Box
Old 12-21-2004 | 11:22 AM
randy41
Default RE: Field Box
It is common to see such tool boxes used as flight boxes.
I have seen ever thing under the sun used for flight box.
The best startes and the other things you mentioned is going to be based
on selfprefrence. So i wouldnt get hung up on brands. Most equipment
now days is good.
I use tower hobbies products quite abit. Mostly do to the fact
that iam a premier member and get double the warranty on tower products.
I ve had good luck out of tower products.
The only thing that i can say as far as name brand is the electric
fuel pump you use to fuel the plane. I have had several that didnt last
long. The only one iam happy with is the Boxxer brand.
