RCU Forums - View Single Post - Engine for Classic Flite Streak?
Old 12-21-2004 | 12:59 PM
gcb
Default RE: Engine for Classic Flite Streak?
A little tourist info you didn't know to ask:
Some of this info comes from posts I've read and some are just my opinions. No guarantees on accuracy...
The original Flite Streak was designed as a combat model and was powered by a Fox .35 combat special. The fuselage vibrated so much, George Aldrich shortened it to cut down on vibration. A modern .20 or .25 has MUCH less vibration and is recommended. A good modern .15 would probably fly it (using 52'x.012 lines)...but I haven't tried it.
The Top Flite versions (original kit, and now ARF) used a modified construction method (as most manufacturers do).
Brodak kit uses GMA's original construction method and was approved by George.
The C/G on the ARF is way back from the original position. I would suggest moving it forward to about 1.5 inches from the wing LE...unless you like real squirrely.
George
