RCU Forums - View Single Post - Clutch setup questions!?
Old 12-21-2004 | 12:59 PM
CEN Racing's Avatar
Default RE: Clutch setup questions!?
There are two different set screws on your shift clutch units. Two that are straight up and down and two that are sitting diagnally. The screw sitting at an angle are the adjusting screws. These are the screws that you will want to start at 4 turns out. The other two simply adjust the balls that ride on the hub.
Thanks for your question.
CEN RACING
