RE: engine cooling
you can put holes in the windshield and another thing that help is- in the rear of the body(like where your headder is) on both sides trim them up a bit(i curve mine) and this will allow the air to escape the inside of the body. also try to get a air filter that stays away from the motor head. so your not pulling heat in the carb. the "motor saver" filter is great.
