RC 1/8th Scale Buggies Discuss the ever popular category of 1/8th scale rc buggies in this forum!
engine cooling
Old 12-21-2004 | 09:21 PM
ratpower396's Avatar
Default engine cooling
I am new to the 1/8th buggy scene & just bought a used in excellent shape ofna ultra lx gt & wanted to know if i would need to cut a cooling hole in the windshield like i had to do on my other nitro vehicles or if the cylnder head poking out of the body is enough to cool it.Thanks for the help..
Old 12-21-2004 | 10:04 PM
proanti1's Avatar
Default RE: engine cooling
Most poeple cut a hole to access their tank, this also serves as a cooling hole. A 2-fer.
Old 12-21-2004 | 10:29 PM
zzman's Avatar
you can put holes in the windshield and another thing that help is- in the rear of the body(like where your headder is) on both sides trim them up a bit(i curve mine) and this will allow the air to escape the inside of the body. also try to get a air filter that stays away from the motor head. so your not pulling heat in the carb. the "motor saver" filter is great.
Old 12-21-2004 | 10:40 PM
whenever cutting wholes in your body don't make sharp edges as it will cause it to crack and split.
