RCU Forums - View Single Post - Genesis steering capabilities (reduce turning diameter)
Old 12-22-2004 | 01:42 AM
Tyre pressure
Default RE: Genesis steering capabilities (reduce turning diameter)
I took of the servo yesterday and today i am going back to the shop where i bought the truck.
No matter if i changed transmitter (used my savage tranny) nothing happened. So i checked the length of the swing of the servo and noticed that when turning right it only moved 65% of the swing when i turn left. So something must be wrong with the servo.
I also noticed that it does not react in the same way as the 5kg throttle servo, the 10kg servo is allot slower in reacting. maybe it should be like this but i do not know...
I have a good relationship with the shop where i bought it... i will let them check it.... otherwise this will go on the warranty.
